P0113 Code will not clear
Old Feb 13, 2025 | 03:57 PM
Jyoung1149's Avatar
Default P0113 Code will not clear
2015 Ford F150 4X4. 3.5 Ecoboost Twin Turbo
Replaced IAT Sensor, MAF Sensor, MAP Sensor. Cannot get the code to clear. Tried to reset ECM by disconnecting the battery. Code will not clear and performance still compromised. (Limited Power) Any ideas? Thanks
Old Feb 13, 2025 | 07:40 PM
Have you ever thought of a bad wiring issue? Just remove the electrical connector, use electronic contact cleaner or 91% isopropyl alcohol to clean, also inspect the connector and its wiring make sure they look good visually.
Old Feb 14, 2025 | 04:32 AM
Some newer vehicles require the repair be made and then the engine run .
If all is well , the code gets cleared by the PCM automatically.
Leefoo
Feb 22, 2016 10:35 AM
MortTheBeast
Jun 21, 2014 08:05 PM
915exp ford
Sep 19, 2009 01:31 PM
rlevy64614
Oct 15, 2007 12:40 PM
rlevy64614
Aug 14, 2007 11:26 AM
