Passenger side brake is grinding/sticking
Old Nov 7, 2018 | 04:30 AM
Celeste Owens's Avatar
Default Passenger side brake is grinding/sticking
I have 2011 F150 I've changed the brake pads, rotors and caliper. Had a guy take a look at the brake hose and it "seems fine." I'm still going to replace the hose. In case it was fine, is there anything else that could be causing this?
Old Nov 7, 2018 | 06:49 AM
Use Common Sense's Avatar
Are your slide caliper slide pins crud free and lubricated? If not, they can cause a caliper to hang up and not center itself properly.
watercutter.cr
Mar 28, 2019 08:58 AM
Aaron Keisler
Dec 1, 2018 02:53 PM
eric hoffmeyer
Apr 21, 2014 08:17 AM
bdw43812
Oct 6, 2013 07:33 AM
a1d2
Jun 10, 2012 07:49 PM
