Power Loss
Old Jul 17, 2018 | 07:15 AM
  #11
F150-07-4.6's Avatar
There seems to be a VCT in the passengers side valve cover but not in the drivers side valve cover..????
Can it be under the valve cover, I have the manual but it's very limited as with just a 5.4 motor not the 4.6...
Old Jul 17, 2018 | 07:48 AM
  #12
Just courious here but is there a reset for the
. fuel shut off switch ???
Old Jul 17, 2018 | 08:22 AM
  #13
Think’n you’re looking at the PCV and it’s electrical component..
The inertia switch is in the right kick panel, but if it were tripped, the engine wouldn’t run at all..
Old Jul 17, 2018 | 08:37 AM
  #14
I just saw on a video that I have to remove the valve cover on the 4.6 2007 in order to get to the VCT valve...
Old Jul 17, 2018 | 09:43 AM
  #15
VCT was for 3v engines.. The 07 F150 was 4.6 was 2v,.
4.6 3v appeared in 09 for F’s
Old Jul 17, 2018 | 04:14 PM
  #16
Oh ok so your telling me that the 07 doesn't have the VCT Solenoid valve or just one on the passenger side ???
Old Jul 17, 2018 | 05:21 PM
  #17
What advances the timing on the 4.6 if it has no VCTs...
Old Jul 17, 2018 | 08:16 PM
  #18
Default I got a code tonight while checking it out again...
P2195
Oxygen sensor signal biased stuck lean bank 1. I was able to get it to go 4 mph... lol
I will be double checking all vacuum lines tomorrow and let yas know how I make out...
Old Jul 17, 2018 | 09:34 PM
  #19
By design, VCT/3V ranges cam advance/retard to make the best HP/torque through a wider range of RPM’s than a standard fixed cam engine.. Race engines tend to run more cam advance because RPM and torque are more needed and build in the top end. For low end grunt, less advance means better low end power pulling from a stop and low RPM as well as good vacuum for power brakes etc.
The 07 4.6 in the F150 has no VCT components.
Ignition Timing corrections are done within the engine management/PCM.. Cam timing is fixed.
One of the things you might check is the idle vacuum value. If you have a gauge, tap into a manifold vacuum source. With/if restricted cats, large vacuum leaks etc the reading may point to a problem. Low vacuum can point to cam issues, cam timing, comp/balance, valve concerns, if they’re ever suspect. As well as emission components in some cases..
Old Jul 18, 2018 | 11:11 AM
  #20
Default No Clue !!!
All plugs are on, Vacuum lines are good and tight, No rotted hoses.. I am baffled now !!! Thanks for all help in advance too ...
