Power Loss
Old Jul 18, 2018 | 11:50 AM
  #21
Lean code needs to be addressed.
Being a single bank lean code, usually takes fuel system delivery off the table,, and fuel filter restrictions etc normally don’t affect idle unless severe. Although, i would certainly check for spec pressure/volume to prove it out.
A minor vacuum leak would not cause the engine to not make power/speed. What doesn’t make sense is that the idle was good prior to the work completed, and not in an area in close proximity to engine management hardware. You reported no codes prior, yet now 2195. 02 is plugged in, no damage? But even with the 02s unplugged wouldn’t cause a dead headed or excessive flat throttle.
Restricted or failing injectors, MAF, can cause lean codes (generally coding tho) PCV, intake leaks, EGR etc.
Being the trucks run condition was bought as unknown,, Comp test results were? Fuel pressure values were? Vacuum reading/value? Establishing base results isn’t a bad idea. Any mod/severe vacuum leak would show up spraying carb cleaner around potential leak areas.
Unless the 2195 was generated removing lines and such, id look at why the bank is overly lean...
Old Jul 18, 2018 | 02:21 PM
  #22
F150-07-4.6's Avatar
Default Going to test the tps and see whats up...
I will let yas know how I make out.,..Ok everything checks out just fine .....WTF...
Old Jul 18, 2018 | 05:07 PM
  #23
Default Fixed
What the problem was ... Was that I didn't know that I had to relearn the throttle body. I found it on Youtube, I just had to disconnect the battery then jump the pos and neg. cables together with out the battery that is. This way I erased all the memory on the computer. Then start it and let it run for 15 min. then take it for a ****ty ride so it can learn the values all over again.. Runs like a champ pretty much and smokes like a bitch because of the sea foam treatment. Thanks for all your help here. I learned some new things...
Old Jul 18, 2018 | 06:59 PM
  #24
Thanks for the update.
Something had to be done that was not mentioned. That is usually why a throttle body relearn is required.
Are you sure the smoke is from seafoam and not some other reason?
Old Jul 19, 2018 | 07:10 AM
  #25
Thanks for your help and all the info too.. I'm just starting off here but sounds fun so far.. eeecchhhhh..lol
Ok it seems i'm getting a slight grinding in the rear end but only when backing up with a turn. When backing up straight no problem... ???
Old Jul 19, 2018 | 07:13 AM
  #26
White smoke, I'm like 90% sure it's the seafoam. The oil level is a bit over full but other than that it's fine...
Update the smoke has stopped...
bradyturk
Feb 8, 2017 11:06 PM
thebigb010
Aug 10, 2015 08:13 AM
daddy2595
Mar 2, 2009 10:16 PM
Nrg_plus_34
Jun 23, 2005 05:12 PM
