pP0401 won't go away
Old Oct 29, 2025 | 05:46 PM
RR/2001/4.6's Avatar
Default pP0401 won't go away
Hello all,
4.6L 200, 168k miles with a P0401 code that won't go away. TB removed, thoroughly cleaned, replaced. Vacuum lines replaces. EGR replaced. I mean you name it, if it's even remotely related to the issue it was replaced or thoroughly cleaned.
P0401 will clear, drive the truck as usual for about three to four days, and the dode comes right back.
What am I missing?
Old Oct 30, 2025 | 07:51 AM
Did you make sure the EGR passages were fairly clean ? They do have a tendency to get blocked with carbon and did you verify vacuum is getting to the EGR valve ?
Old Oct 30, 2025 | 09:16 AM
Old Oct 30, 2025 | 10:33 AM
Hanky,
Thank you for your response. In a word, yes.
Checked voltage (all good) to the various components, removed throttle body / idle air control and thoroughly cleaned.
Replaced EGR and solenoid, DPFE sensor, vacuum lines .
Old Oct 30, 2025 | 10:39 AM
Thanks.
1) '01 - F150 - 4.6L - 2WD - Auto.
2) See original post
Old Oct 30, 2025 | 11:41 AM
Checked voltages ?? Where ?
Do we know if the signal from the PCM is being sent and if it is getting to the EGR solenoid which should if open, should cause the EGR valve to open ?
If you apply vacuum DIRECTLY to the EGR valve when engine is idling , the engine should falter, want to stall, Does it ?
thatboatguy
Nov 18, 2017 03:04 PM
fastdogs
Jun 5, 2013 04:17 PM
bodyman61
Oct 22, 2009 07:37 PM
fishfun83
Feb 19, 2009 04:14 AM
stone
Sep 3, 2006 03:50 AM
