Project Blue Dragon - Custom Overhaul / Electrical / Carbureted Help needed
Old Oct 25, 2020 | 06:39 AM
quake513's Avatar
Default Project Blue Dragon - Custom Overhaul / Electrical / Carbureted Help needed
Welcome to my Blue Dragon project
Some Background Info
The truck started life as a 4.9L that was EFI, around 2017 the electrical system was giving me trouble and I was getting tired of dealing with junk new part, so I talked my wife into letting me spend some on the parts to convert to a carburetor system, With some help from an old friend / boss I was able to overhaul the engine. Installed a single barrel carburetor and had to make a custom wooden spacer plate to lift the carburetor off the manifold, so the butterfly would actuate correctly. Later I had a steel spacer made to replace the wooden one.
Some of What I am wanting to do
  1. Upgrade intake manifold and carburetor to a four barrel.
  2. Remove all wiring harnesses and computers.
  3. Remove dash and build new custom dash.
  4. Fix all rust holes and replace some body panels.
  5. Replacing the fuel system.
Brake Down of My List
Parts I am planing on using.
I am getting my parts from: www.speedwaymotors.com and Amazon
  1.
    1. Ford 240-300 6 Cylinder - Offenhauser "C" Series 4 BBL Intake
    2. Edelbrock 1905 AVS2 650 CFM 4 Barrel Carburetor, Manual Choke
  2. No parts needed here.
  3. Coming Soon
  4. Coming Soon
  5.
    1. Edelbrock 1792 Quiet-Flo Electric Fuel Pumps, 12 psi Max Pressure --- Fuel Pump
    2. Earls 12846ERL HP Billet EFI By-Pass Fuel Pressure Regulator --- Fuel Regulator
    3. Quick Fuel 30-7200QFT Billet Fuel Filter, 175 GPH --- 100 Microns Filter - Stainless Steel Mesh
    4. Quick Fuel 30-7201QFT Billet Fuel Filter, 175 GPH --- 10 Microns Filter - Stainless Steel Mesh
    5. 17 Gallon Aluminum Race Drift Fuel Cell Tank with Level Sender Caps (Black) --- From Amazon
    6. -6AN AN6 3/8" Fuel Line Hose Braided Stainless Steel Oil Gas Fuel Hose Line,Black & Blue --- From Amazon
    Information I Need to Acquire
    1) Since I will be making a new wiring harness, I would like to redo the ignition / spark control brain. ( if that makes sense ) What can I use?
    2) Is there a way to work the A/C system with out using the PCM?
    3) I am thinking about how I would like the new gauges to work; I know that for most of the gauges I would like digital, but for the tachometer and speedometer. I would like to do both analog and digital. So I am think the best thing to do would to make a custom PCB and use something like Raspberry PI to be the brain.? Do you think that would work or is there a better way?
    4) The fuel system is going to have a return line, but I am trying to understand what is better for the fuel filters; stainless steel mesh or paper mesh and what would be the best or better setup for the fuel system, like placments; I.E. pre & post filters, if regulator should be before or after the fuel logger?
    5) If I am using a 12 PSI max pressure. Then should the regulator be rated up or more than 12 PSI?
    6) Would the carburetor I picked out work with the 4.9L engine or would that be to much CFMs?
Tinbender
Oct 24, 2018 09:14 AM
old_stoney
Aug 26, 2013 11:49 AM
raymo46
Apr 29, 2012 07:33 PM
gorygoris
Jan 11, 2012 05:45 PM
Stapuph
Sep 23, 2010 09:13 AM
