Sputtering
Old Mar 20, 2013 | 06:24 PM
WIBOWHUNTER's Avatar
Default Sputtering
I have a 1998 F150 XLT, 4.6 lt. V8. It has 127,000 miles, I bought it used about 8 months ago and it has been fine, I've driven all over on hunting trips with it. But whenever I either "punch" it or am going down the highway doing about 75 it starts to sputter, and almost quit. When this happens the check engine light starts flashing then goes away seconds later. Do I just need to tune it up or is this a more serious fix?
Old Mar 21, 2013 | 06:47 AM
If you have no records of past maintenance , It's always a good move to do some routine maintenance so you know where you stand.
If you can, try to use Motorcraft spark plugs.
A new fuel filter is always a good move.
At that speed there is a high demand for fuel, and a restricted fuel filter could be part of the problem as well as a tired fuel pump.
Try to eliminate the routine maintenance items first, they are easier and cheaper to do.
jd637
Feb 22, 2019 08:14 AM
pedcrash
Jan 6, 2009 04:27 PM
tripletdad
Sep 15, 2008 12:29 PM
amendoca
Mar 11, 2008 05:23 PM
93f250xlt4x4
Mar 22, 2007 10:44 PM
