stalls for no reason
Old Sep 21, 2010 | 06:59 PM
Stapuph's Avatar
Default stalls for no reason
89 f150 300 straight 6 standard 5 speed spit sputtered died towed home. drained entire fuel system no change. replaced tank, fuel pump,sending unit, inline filter, and fuel with pure gas. spit sputtered but quit after a couple of tanks. still won"t start when turned off in hot weather till i let cool for awhile. headed home today no spit or sputter just died. will turn over but sounds like not getting fuel. think old electronics heat sensative. can shoot fuel in intake and runs till fuel gone. think it might be fuel regulator. anyone with same problem? please help. thanks
Old Sep 22, 2010 | 09:02 AM
Bullitt94's Avatar
On your fuel rail there is a little valve that looks like a tire valve. Once is quits, push that valve in. A squirt of fuel should come out. If it doesn't, then you know you have a fuel supply problem.
Be careful with the squirt of fuel on the hot engine!
Old Sep 22, 2010 | 04:53 PM
Stapuph's Avatar
i know i have fuel pressure cause when this happened before i took fuel line loose and was covered in fuel. that is why i"m leaning toward the fuel regulator or something along that line. thanks for the input. any other ideas?
Old Sep 23, 2010 | 09:13 AM
Bullitt94's Avatar
There is a regulator on the fuel rail. Check the rail for pressure after it stalls.
Stapuph
Sep 22, 2010 02:11 AM
CoreyTrevor
Oct 27, 2009 12:54 PM
jrouse
Dec 14, 2006 12:55 PM
butters417
Apr 2, 2005 01:52 PM
butters417
Mar 20, 2005 10:57 PM
