Truck is sputtering on open throttle
Old Jan 14, 2021 | 03:25 PM
Tarik Shalha's Avatar
Default Truck is sputtering on open throttle
I have a pretty strange issue. My 1993 F-150 XL 4.9l L6 starts up fine (most of the time), but I’ve been having an issue when I accelerate. When I put the pedal to the floor all it does is sputter. It’s gotten so bad that sometimes the vehicle won’t go faster than 5mph on occasion. It usually only gets bad when it’s warmed up, but lately it’s been having issues immediately. I’ll tell you what I’ve done to try and fix it:
• New fuel pump
• New fuel hanger
• New fuel filter
• New spark plugs
• New TPS
• New MAP sensor
• Fixed vacuum leak
i really have no idea what the problem could be.
Old Jan 15, 2021 | 03:47 AM
raski's Avatar
I would check fuel pressure, should be 45-60 psi. Do you have any raw fuel coming out of the vacuum fitting on your fuel pressure regulator? Any codes? How's the rest of the ignition system? At night, spray down the wires and cap to see if there is any arcing. Check the cap and coil for cracks and carbon tracking. Check the resistance of the coil. Hang a vacuum gauge off the manifold. Do you have 18-22 inches? When you increase the throttle, does vacuum momentarily drop then go back up as it should? If the vacuum drops down and stays low, that could indicate an exhaust restriction. You have spent enough of your money on parts guessing, now its time to test and diagnose.
Old Jan 16, 2021 | 05:51 AM
I have had vehicles with a defective coil do this. They will not handle the load when the throttle is depressed. If coil is original, worth looking into..
Old Sep 9, 2021 | 06:19 PM
Bill Harlow's Avatar
Im having a similar yet different issue with my 06 XLT 2 valve 4.6. My question is can water splashing up on the coil pacs cause an issue with them??
Old Sep 10, 2021 | 06:39 PM
frank Meo's Avatar
Check the trottle body mounting gasket
They have been known to blow out on the inner mounting side
Doyle
Aug 21, 2017 06:02 AM
viper_dude_06
Aug 13, 2016 07:25 PM
larryc84
Feb 5, 2016 10:48 AM
bam_bam1ca
Jan 5, 2014 08:21 PM
jomando
Apr 29, 2010 01:26 PM
