valve cover leak
Old Apr 27, 2014 | 08:49 AM
James Dupuis's Avatar
Default valve cover leak
I have a 99 ford f150 5.4L with 149000 miles on it. My valve cover is leaking from two of the top mounting bolts. My question: Is there a grommet or rubber seal the goes under the bolts. The valve gasket itself is good. it is just leaking from these two spots. My eye sight is not very good and with all the oil coming from here I cant make it out. Any help would be greatly appreciated.
Old Apr 27, 2014 | 09:22 AM
You should be able to replace the "O" ring on the bolts separately if necessary. Just make sure you get the kind that will hold up to oils.
newyorker
Nov 9, 2010 01:54 PM
genius117
Feb 21, 2009 09:43 AM
sportmo
Oct 21, 2008 01:03 AM
barnall
Nov 6, 2007 08:44 PM
maxt
Feb 17, 2006 10:04 PM
