Vct, timing, and oil pressure issues.
Old Feb 8, 2023 | 05:33 PM
Burronator's Avatar
Default Vct, timing, and oil pressure issues.
Hi, looking for some advice on an older truck.
2007 F150 Lariat 4x4 Crew cab. For a year or so ive had vct timing problems. At warm idle timing started messing up as happens with this issue. I understand what is happening with the lower oil pressure when warm, although im not familiar with exactly how that works with timing and the vct solenoids. But, I dove in and changed the solenoids, keep the oil fresh as I can. No improvement.
From what I understand now, a whole timing and cam phaser rebuild is whats needed along with a higher output oil pump. Thing is with this old truck that has other minor problems and is starting to rust, I dont want to stick that much money into it.
Does anyone know of any other work arounds I could do to improve the problem? Im getting quite tired of driving with both feet, revving the engine in neutral at every red light. I just need the truck to last another year or so.
Thank you so much for any advice!
Old Feb 8, 2023 | 05:44 PM
aquanaut20's Avatar
You primary issue is with oil pressure.
do not throw parts at the old girl until you confirm the oil pressure, get a gauge on it and take a reading.
If the pressure is low, change the oil viscosity to a higher number until the pressure is stable..
Old Feb 8, 2023 | 07:01 PM
Burronator's Avatar
I looked on youtube and Fordmakuloco showed a way to check the 5.4 which involved hooking up the gauge to the oil pressure sensor port.That looked like a hard place for me to get to with no garage or lift. Do you know of an easier way to check it?
Old Feb 8, 2023 | 07:31 PM
aquanaut20's Avatar
That would be the way I would do it..
Coldweatherman
Aug 28, 2021 06:34 AM
Charlene Green
Jun 1, 2020 07:33 PM
Julynn Phalen
Jun 5, 2019 12:10 AM
iemmanuel
Oct 19, 2016 09:55 AM
jaycool47
Feb 16, 2012 06:02 PM
