Vin # confusion help newbie
Old Mar 8, 2021 | 07:58 PM
  #11
Stonz22's Avatar
Here is an interesting truck but sounds suspicious , this is directly from the dealer
Does this make sense or sound correct? Thanks so much !
This one is a 2016 F150 5L Lariat with a spray in box and its here on the lot for you to take a look.
This Lariat is fully loaded. I've also attached the window sticker for all its features it has from factory. The benefit of buying a lariat is the heated and cooled leather seats and its resale value.
https://www.kitchenerford.com/used/v...id10640553.htm
Window sticker
http://www.windowsticker.forddirect....EW1EFXGFA93544
Carfax
https://vhr.carfax.ca/?id=PcFr96ZooY...fwhmbfhhPEWRgI
This 5L does a max towing of 11600lbs but with this truck it can do 8900lbs no problem
. (The last sentence sounds suspicious this is the scarey part )
thanks again
Wayne
Old Mar 8, 2021 | 11:08 PM
  #12
Looked up the VIN..
Built 1/20/16
It had a 4 year extended warranty that expired Feb 1 2021
Crew cab, 145" WB, 5.0, With the tow package listed on the Sticker, GCWR shows to be 14300lbs (Sport Pkg would drop GCWR to 13500lbs)
The truck is a 7000lb GVWR
The combined weight is what should remain in total rate. Fords Towing guide does show 8900lbs Max, meaning 'unladen' or factoring MAX for a basic Curb Weight . Then,,subtract for any in bed payload, passengers/fuel,baggage etc, as well as trailer weight (loaded) and ARC weight for add on's even a spray in bed liner etc that potentially affect both GVWR and GCWR a tad..Not worth mention though..Anything of weight would need to be factored in.
Another bit of insurance/assurance prior to purchase,, is you can have your Ford Service Dept run a no cost Oasis Report on the trucks VIN. Anything done to the truck under warranty, Recalls etc would show on the report..
Brokenrearlockactuator
Nov 3, 2021 08:14 AM
Wuzz Fuzz
Mar 7, 2021 07:55 PM
Akman4201
Aug 5, 2020 09:13 AM
KevIndian
Jan 21, 2020 06:18 PM
lyleb
Nov 23, 2009 04:23 PM
