01 f-350 powerstroke brake line broke
Old Sep 3, 2012 | 03:43 PM
freytag12's Avatar
Default 01 f-350 powerstroke brake line broke
the brake line that needs replaced is laying in between the frame and the gas tank. i dont know whether to take the bed off or just move the gas tank
Old Sep 3, 2012 | 05:16 PM
grindman's Avatar
that should have been a steel brake line. it's going to be a real bear to replace it no matter
what you do because if you move the fuel tank you may not be able to disconnect the filler tube and lifting the bed you may not have enough room between the tank and the frame rail
Old Sep 3, 2012 | 05:58 PM
bandit1948's Avatar
just cut the line at both ends and use a piece of new line and 2 compression fittings ! i did that several times and it won,t leak if you get the fittings tight enough !
billc
Sep 2, 2014 03:33 PM
93f250xlt4x4
Jan 13, 2010 07:53 AM
dylancl2008
Jan 28, 2009 09:31 PM
chester
Sep 28, 2007 06:47 AM
Kevin838887
Oct 7, 2005 04:52 AM
