1959 f250 auto transmission
Old Apr 20, 2019 | 08:01 AM
Mightyox's Avatar
Default 1959 f250 auto transmission
What transmissions would this be?
Old May 23, 2019 | 10:08 PM
frankjr's Avatar
Default Ford automatics
What does the shift indicator look like? If you have a 6 cylinder motor or a 292/312, you probably have a 2 speed Fordomatic which was Ford's version of the Powerglide. If you have a 352, you probaby have either a Borg-Warner 3 speed that starts out in 2nd unless you give it a lot of throttle or shift to Low and then goes to 1st gear. Could also have a Cruise-O-Matic and that has 2 drive ranges. The first range starts out in 2nd gear, and the 2nd range starts in first gear.
Old May 24, 2019 | 07:15 AM
Mightyox's Avatar
Its a 3 speed with a 292 y block.
Old May 26, 2019 | 01:10 PM
ka9j's Avatar
Default 3 speed trans.
If it starts in first gear at partial throttle, it's probably a cast iron Cruise-O-Matic
Old May 29, 2019 | 03:09 PM
Mightyox's Avatar
It dont start at all.
Old May 30, 2019 | 08:08 AM
ka9j's Avatar
Default Ford tranny
OK, what I should have said was "If it starts MOVING in first gear, it's probably a Cruise-O-Matic. Cruise-O-Matics have 2 drive positions, the one closer to neutral will take off in 2nd gear, and the one closer to low takes off in first gear.
There's probably a tag on the transmission saying what type it is. Does the truck ID tag in the left door have any indication on what option the transmission is?
Geoff Riehl
Aug 18, 2012 12:35 PM
Fordtough95
Apr 26, 2012 03:32 AM
Yapalot
Apr 26, 2011 05:29 PM
dilligaf58
Sep 12, 2006 07:57 PM
dilligaf58
Sep 12, 2006 06:55 PM
