1974 F250 390 won’t start
Old Apr 1, 2024 | 12:09 AM
1974_ford's Avatar
Default 1974 F250 390 won’t start
to start here’s a list of new parts on the truckSpark plugs, spark, plug, wires, two ignition solenoids, key ignition, carburetor was rebuilt by shop, new battery, new oil, new gas, fuel pump, fuel line, ignition coil,
the old parts that would matter is distributor and carburetor but the carb was freshly rebuilt
it won’t turn over all it dose is crank and crank
the choke is wide open and has fresh fuel it has spark so i’m stumped
Old Apr 1, 2024 | 09:46 AM
Pull one or two spark plugs. Are they wet or dry ? If wet, possible ign problem, if dry, possible fuel supply problem.
How about a little more history?
Did the the no start condition exist before replacing all those parts?
How did it run ,if it did run, before replacing all the parts
Sometimes we add to the problem in the process of replacing parts, that is why we need all the info you can provide, thanks.
Last, but important question, where were the parts purchased, sometimes parts can be defective right out of the box, especially if imported !!!
Did you check for spark at the plugs? Does carb have manual or automatic choke?
brankuh
Apr 24, 2022 10:36 PM
vlbh81
Jul 4, 2020 01:40 PM
SlimTheHeathngGuy
Jan 2, 2017 04:47 AM
amiehuffines
Sep 6, 2012 07:19 PM
slash
Jan 1, 2005 02:25 AM
