1975 ford f250 tranny shakin
Old Jan 30, 2011 | 09:39 PM
arich's Avatar
Default 1975 ford f250 tranny shakin
hey put took my tranny i n and out to replace ring gear ever since when shiftin from second to third off of a red light (low gear ratio gearbox) my tranny gearbox violently goes to the right . i remember when i put driveshaft back on had previous marks on i had done recently so wasnt sure which side was which could that be it or am i not that lucky please any body out there that can help !
Old Feb 11, 2011 | 10:01 PM
CecilLovelo's Avatar
Thanks. you explained it very easily. I was browsing around for hours, but could not do so. Your post is quite simple and useful
Old Feb 12, 2011 | 07:57 AM
Generally the slip joint on the drive shaft goes to the front of the vehicle.
Driveshaft U joints must be lined up , in phase. The front joint must be in the same position as the rear joint If you did not disassemble the driveshaft you need not be concerned with joint phasing. Are you sure the motor mounts are secure and in good condition?
amiehuffines
Sep 6, 2012 07:19 PM
hotrod
Aug 1, 2010 01:31 PM
santaclaus57
Jan 19, 2010 02:48 AM
jiggles
Aug 28, 2009 09:32 PM
GREASY1025
May 16, 2009 12:41 PM
