1989 5.8L pin out for code port
Old Jun 7, 2023 | 03:59 PM
KST1's Avatar
Default 1989 5.8L pin out for code port
Hello,
I have a 1989 5.8L in my ‘77 Bronco. Since installation years ago, I’ve not had the code test port wired correctly and therefore cannot pull codes.
Does anyone have pin out numbers from the EEC to the various spots on the test plug that I could use to sort this out?
Thanks in advance.
Old Jun 9, 2023 | 12:33 PM
KST1's Avatar
Does this request make sense? Let me know.
Old Jun 9, 2023 | 02:14 PM
What will you be using to read the codes?
Old Jun 9, 2023 | 05:04 PM
KST1's Avatar
I have an older code reader (Actron Code Scanner) but have also used a test light on other rigs.
Old Jun 9, 2023 | 07:47 PM
For the diagnostic plug, do you have the following color wires near it?
TAN / LTGRN
WHITE / BLK STRIPE
YELLOW /LT GRN coming from TFI module
Maybe our Moderator can come up with a wiring diagram for the 89.
I will try to go thru some of my library and see if I can find what you might need..
JaviGold
Mar 14, 2023 10:41 AM
61 2DOR
Oct 10, 2011 10:46 AM
HansonHVAC
Oct 31, 2007 06:33 PM
anlufu
Feb 19, 2007 11:44 AM
jec327
Dec 12, 2006 01:27 PM
