1989 F250 Error Code 67
Old Mar 7, 2023 | 09:35 AM
JaviGold's Avatar
Default 1989 F250 Error Code 67
I have a 1989 F250 with 351W and E4OD transmission. I'm getting an error code 67. Also, my OD off light stays on (solid, not flashing) and won't change. I have changed my neutral safety switch with no luck.
Any ideas? Thanks!
Old Mar 7, 2023 | 04:58 PM
Can you unplug the plug at the manual lever position sw on the side of the trans?
Does the light go out with the key on, yes/no?
Old Mar 13, 2023 | 02:26 PM
JaviGold's Avatar
I unplugged the neutral safety switch and turned the key on. The light is still on. Starter will not turn over now, of course.
Old Mar 13, 2023 | 04:26 PM
The reason we had you check with the plug off the sw on the trans was to eliminate a shorted part in the trans.
Now we know there is a short to ground with the wiring in the column or on down to the switch on the trans.
Old Mar 13, 2023 | 04:41 PM
JaviGold's Avatar
Ok great. Do you know what color the ground wire is for the switch? Thanks!
Old Mar 14, 2023 | 10:41 AM
With older vehicles you can utilize a test light, but must be very careful with newer vehicles due to the extensive use of electronics and a heavy load from a test light can produce addl problems.
Using a test light you can determine which are power wires and which might be ground.What we want to verify is there should be no ground to the indicator lamp when in the on position..
When you activate the switch the light gets a ground and should tell you OD OFF.
bobbytowery
Feb 6, 2026 06:50 PM
Tjc359
Jan 23, 2018 08:33 PM
Madmardigan
Jul 6, 2010 07:57 PM
site2site
Sep 29, 2008 08:09 PM
a_cmc_2b
Feb 6, 2008 09:47 PM
