1999 f-350 7.3
Old Jun 11, 2020 | 07:42 AM
Tom Ferstl's Avatar
Default 1999 f-350 7.3
My check engine soon light came on and it went off after cranking engine for a couple days. Now the Check Engine Soon light stays on and the engine shuts down after about 2-5 minutes! re-crank and the same thing happens again! Any ideas/suggestions it might be the cause! It appeared a couple days after topping off diesel fuel at MurphysUSA where I have always got my fuel. It has 80k mikes and I seldom drive it which is the reason for the low mikes!
Old Jun 11, 2020 | 11:23 AM
The fuel topping off may or may not apply.
Does the "WATER IN FUEL" lamp stay on when cranking the engine? If it stays on, check fuel filter for water contamination.
Old Jun 11, 2020 | 01:00 PM
Tom Ferstl's Avatar
The water in fuel does not come on! Thanks
Old Jun 11, 2020 | 01:04 PM
bismic's Avatar
Check for codes with a good code reader. ForScan Lite on a smartphone will work. You will need an OBDII adapter.
Also, have you ever replaced the cam sensor?
Zrowayz713
Mar 19, 2018 01:05 PM
Sam Fasano
Sep 9, 2012 09:44 PM
hclark
Sep 21, 2009 09:45 AM
concrete guy
Jul 23, 2008 06:50 PM
BillsFan
Jul 24, 2007 07:17 AM
