2000 f250 super duty v8
Old Oct 8, 2019 | 04:44 AM
Dan Taylor's Avatar
Default 2000 f250 super duty v8
I've been going crazy trying to find out where to get the socket that fits 2 of my spark plugs. I've seen/ read somewhere that there at 2 that require a special socket. The regular one is to big. Where do I get this and what is it called ?
Old Oct 8, 2019 | 02:59 PM
If you go to a regular auto supply store like NAPA , Advance, etc., ask to see their "Spark plug sockets" and you can decide just which one you want.
There is a long one that has a knurled finish on the top that helps make removal and installation easier.
Old Oct 8, 2019 | 03:19 PM
Dan Taylor's Avatar
I've been told there are like 2 plugs that are smaller or something like that
Old Oct 8, 2019 | 03:38 PM
Not so !
They are all the same !
If you are new to this or unsure, you might get some idea of just what is involved if you check a few videos on u tube.
Changing spark plugs is not usually too difficult if you have the right tools and ,,,,,,,,,,
Get the correct replacement plugs
Make sure the gap is correct for your particular vehicle engine
Blow out any grit before removing the plugs
Always start the replacement plugs by hand ,they should turn easily on starting to install
Hold the socket perfectly straight when tightening to the correct torque (approx 17 ft lbs otherwise there is a chance of cracking a new plug. Plug is now destroyed.
Apply dielectric grease to the terminal and boot that goes on to the plug
Old Oct 9, 2019 | 03:51 AM
Dan Taylor's Avatar
Ok. I've done plugs a ton of times. This truck is new to me and never had this issue. But Ill keep trying. Thanks
Old Dec 23, 2020 | 06:00 PM
white1's Avatar
9/16 deep socket on some
RichL47
Apr 18, 2024 09:48 PM
Patriotsfan78
Oct 27, 2008 08:51 AM
dsljay
Oct 20, 2008 12:19 AM
ccs95
Oct 29, 2007 02:40 PM
Sparkplugs.com
Dec 1, 2006 03:02 PM
