2001 f250 5.4l cranks no start
Old Oct 4, 2023 | 01:55 AM
Ostrichsizer's Avatar
Default 2001 f250 5.4l cranks no start
I have a 2001 f250 5.4l that I've been having trouble with recently, it all started with the truck acting like it was vapor locked on long trips (stalling out then wouldnt start for hours) and now won't start at all, it acts like it either isn't getting fuel or the air mixture is off, I've went through and replaced a lot of parts (fuel pump, fuel filter, throttle position sensor, mass airflow sensor, fuel injectors, ignition coils, spark plugs, catalytic converter) the only code it's currently throwing is an EGR code but my truck has no EGR (thus the catalytic converter replacement) the only things left that I can think of is the pcv valve and the purge solenoid and I could really use some advice from anyone who might've run into the same thing.
Old Oct 4, 2023 | 10:21 AM
You might want to check the crank sensor.
Old Oct 4, 2023 | 02:08 PM
I'll add it to the list, thank you!
Old Oct 4, 2023 | 04:38 PM
Mr. O
If you have the $$$ to blow, fine.
If you want to be reasonably sure the crank sensor is the problem, when it gets warm and quits running, just throw some cold water on the crank sensor and see if it starts. If it does,THEN,,, you replace it.
That is what I meant when it was suggested to check the crank sensor.
Ostrichsizer
Oct 4, 2023 01:54 AM
wim339
Oct 18, 2021 07:02 PM
Trizz5253
Apr 21, 2021 09:10 AM
motoxman.21
Jun 10, 2010 07:22 PM
jelmore
Apr 19, 2007 02:05 AM
