2002 F250 Wipers and washer do not work
Old Mar 28, 2018 | 05:27 PM
Bubba's Avatar
Default 2002 F250 Wipers and washer do not work
02 F250,, all of a sudden the wipers will not work,,, when I push the Washer button,, I hear a slight click under hood but no spray,,,,, in the manual there are 3 references to wipers,, a couple must not apply to my truck,,, Fuse 21 25A Rear Wiper motor; Fuse 33 15A Front Wiper; Fuse 106 Front Wiper Main 30A,,,,, I have heard of the green wire going to motor can get damaged and fail,,,, and some kind of moisture issue in fuse panel under steering wheel,,,, what is the route this green wire takes from motor to fuse panel, so I can intercept it somewhere to check voltage,,??
Old Apr 6, 2018 | 09:18 PM
Bubba's Avatar
So wipers are repaired and working now. After spending 29$ for a supposed wiring schematic for a 2002 F250 SD,,,, which was somewhat wrong, the schematic people first said my owners manual was wrong,,, but later said must have been a mid season change in the F250 wiring. My fuse panel cover says the wiper [Main] is a 30 amp Fuse # 106,,, the schematic says it is #54,so you have to be somewhat of a detective to use schematic. The problem was the main Dark Green wire, from fuse to wiper motor, not a fuse, connection or relay, but the wire itself had failed. the failure was somewhere between from 4 or 5 inches past under dash fuse,,, and big multi wire connector under the hood,,,,, about a 3 foot section,,, never found the actual break,,,, I just cut Dark Green wire at fuse block, and big connector and added a new #12 bypass wire,,,, now, all works as it should. The Dark Green wire goes from fuse 106, direct to wiper motor,, and is HOT when key is on. A wire failure seems almost impossible,,, and if it was melted ,,,,,, maybe all the wires near it, in the bundle, are injured a little, dunno' ? This Dark Green wire, is in a big bundle that passes through firewall, that travels from big connector, to fuse panel. No fuses under hood,,,, all fuses are under dash left side.
Old Apr 6, 2018 | 10:42 PM
Thumbs up
Thanks for the update..
If you need any future schematics, diagrams etc let us know before you cash out..
1960nick
Mar 4, 2018 08:58 PM
fmadelman
Oct 23, 2017 08:47 AM
travis s
May 23, 2013 05:45 AM
bernieb
Mar 11, 2011 03:50 PM
Diane
Oct 4, 2010 05:57 PM
