2004 6L no start
Old Oct 7, 2020 | 09:58 AM
  #11
bismic's Avatar
Well, if you are sure of the ICP pressure value, then it is either a standpipe leak, an injector leak, or an oil rail leak.
Leak testing at each rail (or through the IPR port) is recommended. Do so with the valve cover off and listen real well at each injector.
Old Oct 7, 2020 | 01:47 PM
  #12
McDontw's Avatar
can I use the ICP port? I don't have the fitting for the IPR
Old Oct 7, 2020 | 02:21 PM
  #13
bismic's Avatar
Yes you can. It is slightly less reliable because an IPR issue can cause you to fail the testing. On the later year models it isn't as effective because the ICP is on the passenger oil rail and the air has to flow in reverse direction past the passenger standpipe.
Since you are sure of the IPR valve, then it is no issue.
Old Oct 7, 2020 | 05:16 PM
  #14
McDontw's Avatar
i think I could air charge the oil rails directly. If I use the ICP port do I need tp power the IPR to open it?
Old Oct 7, 2020 | 05:22 PM
  #15
bismic's Avatar
The IPR is a "bleed-off" valve. The only flow past it (or through it) is the oil bleed flow to the crankcase. You must close the IPR valve to do the air test. Even if you pressurize the individual oil rail through a rail plug, the IPR needs to be commanded closed.
Old Oct 20, 2020 | 04:15 PM
  #16
McDontw's Avatar
So I finally did the air test on the individual oil rails. Got some serious gurgling. Used my stethoscope and found the gurgling to be strongest at the top of the stand pipes. about equal on both sides even when air to only one side. it was pretty loud. could this be the drain off on the pump? I will remove the stand pipes and re O ring. Then re-air test. any thoughts?
McDontw
Jun 27, 2020 11:08 AM
Van Bay
Mar 21, 2015 10:35 PM
tragon
Dec 24, 2011 06:14 PM
cory meyer
Apr 30, 2011 07:13 PM
alignmatt
Jan 1, 2009 11:12 PM
