2004 f-250 dies while driving down the road
Old Sep 18, 2018 | 07:01 PM
Sandman88's Avatar
Default 2004 f-250 dies while driving down the road
I just bought a 2004 f-250 6.0L with 234000 miles. While I’m driving down the road it’ll die, I’ll turn the key off and it’ll start right back up. I was told it was a sensor but don’t know which one.
Old Sep 20, 2018 | 10:29 AM
bismic's Avatar
Common sensor and wiring issues
ICP sensor and connector
EBP sensor and connector
FICM and FICM harness
IPR harness chafed
Check for codes with a quality code reader. Should give you a clue as to where to look.
Old Sep 20, 2018 | 09:50 PM
Sandman88's Avatar
I drove it again today and figured out that if I pump the throttle while it’s trying to die it’ll keep it going for a couple seconds longer. It’s acting like it’s not getting any fuel. Which is making me think ficm more and more. But the guy I bought it from had the injectors replaced on one side and not the other so idk if that could be the problem or not.
Old Sep 25, 2018 | 04:19 PM
Sandman88's Avatar
Default High pressure oil
I took it to the shop. It’s loosing high pressure oil. He said in the 16 yrs that he’s been doing this he’s never seen a truck do what this one is doing.
Old Sep 27, 2018 | 07:54 AM
bismic's Avatar
lol - engine dying and then starting right back up isn't a mechanical issue w/ the HPO. As stated, it is almost always electrical, and again, the ICP and its wiring is the most common issue
good luck with it.
Thager23
Sep 12, 2018 09:11 PM
eeguy1953
Jan 11, 2009 01:37 AM
Sooner0233
May 1, 2008 09:53 PM
lthacker
Mar 5, 2007 10:59 PM
hicracer
Jan 31, 2005 10:40 PM
