2004 Ford F-250 superduty 6.0 no start
Old May 18, 2020 | 01:59 AM
Jake Manning's Avatar
Default 2004 Ford F-250 superduty 6.0 no start
So I recently put in a new used intake manifold, got everything hooked back up, and when I turn the key, my lights flicker, it throws a glow plug check dash like as well as ABS and battery light. Will not even crank. I have no idea what to do.
Old May 18, 2020 | 07:29 AM
bismic's Avatar
Verify all electrical connections are on solidly with no corrosion (this includes the alternator sensing wire)
Charge batteries (individually is best)
Load test batteries (individually is a requirement)
Take alternator in and have it tested
Assuming you have healthy batteries that are all charged up, and a healthy alternator, then you can try cranking by disconnecting a yellow wire (with blue stripe) by the passenger fender (and by the vacuum pump and climate air blower) and jumpering it to the passenger battery (+) terminal. Do this with the key off. This will/should crank the starter.
Old May 18, 2020 | 09:59 AM
I checked the battery wires those are good, the batteries were great when I unhooked them. Alternator is ok.
I will look around better and see if I missed anything.
Old May 18, 2020 | 10:08 AM
bismic's Avatar
Please charge and load test the batteries. I assure you one can fail quickly and you can't tell without the proper testing.
Many of us have been through this a BUNCH of times .......
Oh, and that battery light is 90% of the time an alternator issue (which can cause battery issues).
Old May 18, 2020 | 10:33 AM
I can load test and test the batteries, and check the alternator again when I get off worK. And it also doesn’t ding when I turn the key.
Old May 18, 2020 | 12:03 PM
Strange things happen, check all the fuses, those under the hood and those in the dash Quick when you use a test lite.
All grounds connected, sometimes we miss one.
Old May 20, 2020 | 10:21 AM
I’ve got the batteries charging cleaned all the corrosion I could find. I’ll take in my alternator and see what happens. I was already able to get it to crank over with the yellow wire.
Old May 22, 2020 | 09:20 PM
So I had to get two new batteries and one alternator was fine and the other he said was 50/50. And I’ve used the yellow wire on the battery to turn it over and build up oil pressure. And I’m still waiting until I can start it.
Old May 23, 2020 | 01:51 AM
bismic's Avatar
What does that mean?
Old May 24, 2020 | 01:54 PM
What I mean is after I get the high pressure oil pump up to par then hopefully I can start it up for real or at least be able to check it for codes.
