2007 F-350 6.0 Hard Start & Rough Idle at Start Up
Old Feb 2, 2026 | 11:27 PM
T777K's Avatar
Default 2007 F-350 6.0 Hard Start & Rough Idle at Start Up
Hi All,
I just acquired a 2007 F-350 6.0 it's in great shape but when started cold it takes more cranking than it should after glow plug light goes off and it idles very rough for a couple of minutes then smooths out.
what could be causing this? I'm thinking fuel system getting air and letting the fuel bleed back while sitting. Any advice on where to start looking? Thanks
Old Feb 3, 2026 | 04:19 AM
Might be a good move to verify the glow plug system is working.
Do you have any kind of test equip ? A simple test light can help with some of the answer.
Old Feb 6, 2026 | 06:49 PM
bismic's Avatar
FORScan Lite on a smartphone (iphone), or full version on a Windows laptop, or even Torque Pro on an Android device will get you the ability to read codes engine Parameters and to pull codes. These are essential for any owner to troubleshoot his/her own 6.0L. The cost for these are reasonable and the learning curve isn't too significant. Anyone worth their salt will be hesitant to guess.
Old Feb 8, 2026 | 09:23 PM
T777K's Avatar
Default Thanks you two. I have one of those FixIt code readers. That should work, shouldn't i
Thanks you two. I have one of those Fix It code readers. That should work, shouldn't it ?
Old Feb 9, 2026 | 09:19 AM
Can't tell from here . Try it and see what it tells you,then maybe post it here.
Richardtbeland
Nov 19, 2025 04:21 PM
Alton Robinson
May 4, 2021 02:30 PM
whitings76
May 31, 2016 09:13 AM
Superdutyman
Dec 17, 2009 08:19 PM
Dan0Holt
May 16, 2009 09:40 AM
