2008 Ford F250 wet windows
Old Sep 19, 2024 | 10:02 PM
Jackiejack's Avatar
Default 2008 Ford F250 wet windows
I recently got this truck and don't know much about it except it was a 1 owner truck. The problem I am having is all the window get dew on them on the inside and it is making it smell like mildew. There are no apparent leaks. I owned a lot of vehicles and this is a first time, for this issue. I live in Florida and it has rained almost everyday for almost 3 weeks, so it is pretty humid out there. If it was a leak how would all the windows have dew on them on the inside? Any suggestions would be greatly appreciated. One more thing I also have a car and it does not have this issue.
Old Sep 20, 2024 | 06:30 AM
Maybe a silly quest1ion, does your truck have air conditioning that works ?
Please keep in mind air conditioning doesn't only cool , it dehumidfies , removes moisture, from the incoming or inside air.
The moisture it removes has to have a way to exit the vehicle and that may be part of the problem.
Hear any strange squishing noises when blower is operating ?
Old Sep 20, 2024 | 07:35 AM
Jackiejack's Avatar
At present I am working on the AC so not it is not working at present. I do not hear any strange noises when the blower is running. I am pretty close to having the AC working, I will update if that solves the problem. Thank you for your reply.
Old Sep 20, 2024 | 08:32 AM
On the passenger side firewall there is an evaporator drain, a small flat tube that allows for AC moisture collected to drain.
Please make sure that drain is not blocked, all part of a good repair..
Let us know how you make out with this, thanks.
johnwin
Sep 7, 2022 01:58 PM
Melissak
May 16, 2022 05:53 AM
Big Wally
Jun 8, 2018 07:17 AM
CarrieM1980
Oct 19, 2011 08:44 PM
Matt in MI
Sep 18, 2008 01:10 PM
