2013 F250 4x4 popping noise
Old Feb 3, 2025 | 04:50 PM
Rayzor5858's Avatar
Default 2013 F250 4x4 popping noise
When turning the steering wheel sharply in either direction while backing up or moving forward I am hearing a popping noise coming from middle underneath truck. Thinking it may be from frame flex I have looked at the cross member at the back of the transmission for rust around the bolts and also have checked for bolts being loose. No rust and bolts are tight
anyone experienced this noise before?
Last edited by Rayzor5858; Feb 3, 2025 at 05:35 PM. Reason: The popping noise only happens once in reverse or forward direction
Old Feb 3, 2025 | 06:17 PM
For a start,,,,,,,,,,,,,,Check for a wheel that might have loose wheel nuts.
Some times a worn CV joint up front will make a popping noise .
Old Feb 3, 2025 | 08:15 PM
Rayzor5858's Avatar
Thank you sir I will do that
Old Feb 17, 2025 | 09:06 AM
ritawong's Avatar
Clunking noises when cornering can sometimes be caused by worn suspension bushings or steering knuckles.
Old Feb 17, 2025 | 12:59 PM
Rayzor5858's Avatar
I have replaced 3 tie rods and had a front end alignment
seems that was the problem with the popping noise
CV joints and other related front end items were ok
thanks to the folks that replied to thread
GQuad73
Sep 10, 2022 03:19 AM
Jax280
Jan 29, 2019 12:10 PM
f-150-silver
Oct 25, 2018 05:40 PM
newfordf15013
Oct 27, 2015 03:29 AM
frankf250
Aug 20, 2009 02:30 PM
