2024 F350 Cruise Control problem
Old Feb 17, 2025 | 10:46 AM
Robin1957's Avatar
Default 2024 F350 Cruise Control problem
Basically, it stopped working, then started again, then stopped...you get the picture. We've ensured the sensors are clean and unobstructed. We see a notice on the display of, "...requires technical service" or something like that. We will likely need to take it in for maintenance, but if anyone out there has ideas for a DIY fix, please post. We are on a long cross-country trip.
UPDATE: A pal suggested resetting the computer system by disconnecting the battery and reconnecting after a short wait. IT WORKED!
Old Feb 17, 2025 | 04:46 PM
Are there any signals on the display when it quits ?
Old Feb 17, 2025 | 05:13 PM
DIY fix check your brake lamp and its operation, then check your brake switch and see if it's loose or sticking.
Old Feb 17, 2025 | 05:54 PM
Robin1957's Avatar
Angry
Even when the cruise control is working (off and on, as I said), I have indicators come up advising us "SERVICE ADVANCE TECH". Seems something in the electronic brain has gone bad. 😒
Old Feb 17, 2025 | 07:17 PM
Could that be saying, Service Advance Trac which could involve stability control ?
Old Feb 17, 2025 | 07:46 PM
Robin1957's Avatar
Yes! Now that I think more about it, I think the display did say, "Service Advance Trac". So, what does that indicate/mean?
Old Feb 18, 2025 | 08:23 AM
This involves quite a few sensors.
Among which are,, wheel speed sensors
Steering torque sensor
Acceleration sensor
Anti lock brake system
Lateral motion sensor
Accelerator pedal sensors
If vehicle stability is concerning at the time it can cut power to the engine using the throttle body
SO,,,,,,,,,,,as you can see this is more involved than what can be diagnosed without the required equipment and knowledge.
bux4brainz
Aug 6, 2024 08:59 AM
tommy6464
Jun 7, 2024 10:56 PM
allotoi69
May 1, 2024 03:45 PM
350stretch
Aug 21, 2021 07:42 AM
akgriffin
Mar 17, 2013 06:07 PM
