2013 F250 FX4 Shocks
Old Feb 7, 2018 | 06:15 AM
ktuckyragr's Avatar
Default 2013 F250 FX4 Shocks
I have the F250 Lariat FX4 4X4 and am need of any info on what shocks to replace the Rancho's that are on it. It squats when my travel trailer is hooked up to it.It' a 30 ft trailer. Should have no problem. I have looked at the Bilstein and Pro Comp shocks but not sure. Any ideas?
Old Feb 7, 2018 | 05:06 PM
Have you had a chance to check the combined gross vehicle weight of truck and trailer?
Some states have limitations on what a certain rated vehicle can legally pull? There are considerations regarding tongue weight of the trailer when hooked to the truck.
That is not my so called field of expertise and hopefully someone with the required knowledge will pitch in an help you here.
Old Feb 7, 2018 | 08:10 PM
ktuckyragr's Avatar
The weight of the trailer and its tongue weight matches the truck and the truck has no problem pulling it. When the trailer is hooked up and level the tail end of the truck has squatted down, not much but enough to see.Just want to know what rear shocks would help.
Old Feb 7, 2018 | 11:10 PM
Use Common Sense's Avatar
Shocks don't help with the squatting issue unless they are "COIL OVER" shocks. I would try a weight distributing hitch is you're not already using one. The other option would be to install a set or quality airbags. You could also use an "ADD A SPRING", or install a set of F-350 springs.
Old Feb 8, 2018 | 10:11 AM
eric hoffmeyer's Avatar
I have a set of airbags on my F350. Very helpful.
Eric
Bnard2345
Mar 18, 2019 04:56 PM
ktuckyragr
Feb 6, 2018 09:20 AM
csearing
Nov 2, 2013 10:53 PM
renatosc123
Sep 15, 2013 04:08 AM
rjmart1013
Apr 7, 2013 12:50 AM
