2014 6.2 4x4 issue
Old Jan 25, 2022 | 08:24 PM
350 super doody's Avatar
Default 2014 6.2 4x4 issue
My 2014 F350 6.2 has a new 'used' transmission. Long story short, transmission shop installed, now 4x4 doesn't work (yes i took it back, they're clueless, why i am here). When I put the dash selector in 4wd, everything appears to be working, I hear the transfer case motor clicking, but I have no power to my front axle. If I manually lock the front hubs, when the truck rolls the axle and front drive shaft turn with them... so I'm thinking the problem is in the transfer case. As far as I know, the transmission shop only removed/replaced the transfer case while doing the transmission. Is there something they could have left out?
Old Jan 26, 2022 | 07:46 AM
Maybe they failed to connect the electrical wiring.to the shift motor.
Old Jan 26, 2022 | 08:41 AM
Thanks, I checked... all is wired and I hear the typical clicking when engaged... losing my mind over this.
Old Jan 26, 2022 | 08:17 PM
Default Update
Today I pulled the transfer case motor and tested, it functions normally. I also put a wrench on the output shaft while it was exposed.... I can't move it. Has anyone ever mated a transfer case to a transmission? Is it possible to connect them incorrectly so that the insides of the transfer case bind up?
Old Feb 7, 2022 | 08:11 PM
scott.butler4's Avatar
I'm not sure how the transfer case would have gotten screwed up by replacing the transmission, that said I would go back to whoever replaced the transmission assuming it worked correctly beforehand.
spodris
Jan 2, 2023 01:00 PM
Frogdude69
Dec 18, 2021 04:13 PM
mblackwolf
Jan 26, 2011 03:18 PM
77ford400
Dec 22, 2010 10:35 PM
aintsaword
Nov 17, 2005 12:51 PM
