2024 f 350
Old Jun 17, 2025 | 07:07 PM
Tfordy's Avatar
Default 2024 f 350
Onboard power only gets upto 200or 500 watts and trips out and says exceeds power output. Has anyone elese had this problem ford says they haven’t seen it in this truck.
Old Jun 18, 2025 | 07:32 AM
Usually a message like that tells us whatever is plugged in and drawing power from the system is exceeding what the system can safely provide.
Can we ask what kind of equipment are you attempting to operate and do you know how much power it draws ?
Old Jun 18, 2025 | 08:17 AM
Tfordy's Avatar
1/4 horse air compressor 1400 watts and a chop saw not sure on the wattage draw on it though had a dodge ram that it would work off the outlet in the cab till the air compressor would kick off and go to kick back on then it would trip out
Old Jun 18, 2025 | 12:16 PM
Does your owner's manual provide the maximum wattage the vehicle is capable of putting out ?
Old Jun 18, 2025 | 03:52 PM
Tfordy's Avatar
2000 watts 1500 while driving.
Old Jun 18, 2025 | 07:08 PM
If your vehicle's system is supposed to be able to supply that much power, just like in a home, a circuit breaker will trip if the circuit demand is more than it can safely handle..
I would suspect the protection (Breaker) in the vehicle. A good electrician should be able to check and verify if this is what is defective.
61comet
Jun 18, 2024 10:49 AM
acinatx
Jun 15, 2021 07:33 AM
snyderryan65
May 17, 2008 12:22 AM
greuelc
May 2, 2007 01:30 AM
ford4j
Oct 29, 2006 11:38 PM
