7.3 power steering no sound no power
Old Aug 20, 2020 | 05:56 PM
Gerad Hardin's Avatar
Default 7.3 power steering no sound no power
Good day diesel guru’s! I was driving my 7.3 when the engine cut out. I turned the wheel to make a U for a safer landing, and all the sudden my steering became almost nonexistent. When I finally stopped I saw that the hydro boost line had popped from the pump. I replaced the line only to find out the pump had also died. After replacing that, I flushed the lines and took it for a quick spin around the block and everything was fine. No noise, brakes worked, steering was on point. After about 2 miles, brakes and steering almost totally went out, but no noise from the pump... I used ATF as the power steering fluid. I flushed it from the return port of the pump. What could be wrong? Thank you!!
Old Aug 20, 2020 | 06:16 PM
If you let it set overnight you might find the level has dropped . Maybe all the air was not purged.
If all is OK , possible problem with faulty pump.
Old Aug 20, 2020 | 06:43 PM
Thanks, I let it sit over night and tried doing the left/right maneuver again. No love... could I have gotten a bad refurb or does it need to sit longer?
cpye2
Mar 11, 2016 10:30 AM
camoman33
Jul 7, 2012 02:09 PM
holamoc
Jun 25, 2011 10:54 AM
tdrn
Aug 30, 2007 07:32 AM
strider380
May 20, 2006 11:10 PM
