7.3L issues need assistance with diagnosis
Old Jan 23, 2020 | 08:30 PM
Jay Anderson's Avatar
Default 7.3L issues need assistance with diagnosis
So this issue just started last night, I went to start my truck (waiting for the glow plug light to shut off before start up) and started the engine. She idled at around 750 (or normal idling RPMs) and then she shot up to about 1100-1200 RPMs and at that point the engine began to shake vigorously as did the whole truck. (She held constant “idle” there for some time before I turned her off) Never ran into this issue before and was wondering if someone has some insight on this issue. It’s not the ICP or CSP sensor as both of those were already replace FYI (to rule out possibilities)
Also on the side note, when I press the accelerator pedal, she jumps very high to 2500-3000 RPMs as if I slammed the pedal to the floor.
Old Jan 24, 2020 | 08:13 AM
bismic's Avatar
Sounds like an injector issue to me. Got anything to scan for codes?
Old Jan 24, 2020 | 08:48 AM
I check my scan tool (expensive one) and nothing I found was popping up nor did the check engine light which I found odd. But yes scanned everything and and nothing. But will be performing an Injector Buzz Test this evening.
Old Jan 25, 2020 | 04:35 AM
Sometimes air getting into the fuel supply can cause this type problem.
Might be a good idea to check the fuse panel SJB for moisture or corrosion.
Old Jan 25, 2020 | 07:07 PM
I ran my other code scanner while the truck was running and not running.
Codes:
P0269 - Cylinder 3 contribution/ balance fault
Engine & Powertrain
P0541 - Intake air heater circuit low
P0113 - IAT circuit high input
P1211 - Injector control pressure above/below desired
Generic Electronic Module:
B1352 - ignition key-in circuit fault
B1318 - low battery voltage at module
B1359 - ignition run/accessory circuit fault
Old Jan 26, 2020 | 04:48 AM
You might consider trying this;
Write down the codes you received so far, clear them, then clean all the electrical connections you can find starting right at the battery.
You didn't say what year your vehicle is, some had problems with leaking windshields and that moisture leaked onto the Gem module /fuse panel and all sorts of crazy problems appeared. Suggest you check the fuse panel for rust/moisture in that area and clean it if found.
Old Jan 26, 2020 | 08:38 AM
My apologizes, it’s a 2000 F250 crew cab 7.3L 4WD
QUOTE=hanky;117246]You might consider trying this; Write down the codes you received so far, clear them, then clean all the electrical connections you can find starting right at the battery.
You didn't say what year your vehicle is, some had problems with leaking windshields and that moisture leaked onto the Gem module /fuse panel and all sorts of crazy problems appeared. Suggest you check the fuse panel for rust/moisture in that area and clean it if found.[/QUOTE]
Richee
Mar 24, 2019 04:40 PM
only1bigdaddyo
Apr 28, 2013 06:26 PM
dieselman21585
Jul 23, 2007 01:21 AM
guma
Sep 13, 2006 02:50 AM
shoreline
Oct 30, 2005 10:14 PM
