91 f250 5.8L gasoline w/ s5-42 transmission
Old Nov 15, 2023 | 05:00 PM
StevesHHS23's Avatar
Default 91 f250 5.8L gasoline w/ s5-42 transmission
Hello!This is my first pick up and manual transmission. It has a granny gear for 1st so I usually start in 2nd. I got a great idea to punch it in 1st to see how fast it get get off the line. It revved up really high. I tried to put it into 2nd but it wouldn't go into gear. Now it can't shift into any gear when the car is started and it grinds if I try to put it into reverse. If I start it while in second gear and the clutch peddle to the floor it still rolls forward slowly. Any ideas? Thank you for reading this.
Old Nov 16, 2023 | 08:53 AM
If the vehicle has a hydraulic clutch system, there most likely is a problem within the system that is not allowing the clutch to completely release.
Old Nov 16, 2023 | 09:22 AM
It does have a hydraulic clutch. I'm not great with fixing cars but I'm learning. Any ideas on what I could do to confirm what part needs to be replaced or repaired?
Old Nov 17, 2023 | 05:53 AM
Is the reservoir for the clutch master cyl full with the required fluid?
When you go to depress the clutch pedal,there should be about 1 inch "Free ply" before you feel any resistance. What does your vehicle have?
StevesHHS23
Nov 15, 2023 04:06 PM
Mightyox
May 30, 2019 08:08 AM
Fordtough95
Apr 26, 2012 03:32 AM
arich
Jan 31, 2011 04:15 PM
dilligaf58
Sep 12, 2006 06:55 PM
