92 ford f-350-fuel problems
Old Mar 23, 2011 | 11:57 AM
pell's Avatar
Default 92 ford f-350-fuel problems
I have a 92 f-350 with the 4.9 auto. I have a problem were the fuel pump will not always start when the key is turned. I replace the pump but it still happens. It does not do this all the time,however sometimes I turn the key up to 20 times for the fuel unit to kick in. I know were the relays are yet I do not know which one it is. Any ideas?
Old Mar 23, 2011 | 01:39 PM
There are a couple of relays there that are the same. Sometimes switching them will correct a faulty connection. You could also remove them one at a time and when you don't hear it drop out you know you found it.
The computer is supposed to energize that fuel pump relay for 2 seconds unless you crank the engine over then an RPM signal is supposed to keep the relay energized.
You do need to wait a few seconds between tries if checking the 2 second thing.
Old Mar 24, 2011 | 09:46 AM
pell's Avatar
This truck is not running at all. what would happen if I hot wire the pump and run it that way?
Old Mar 24, 2011 | 12:47 PM
Does the truck run alright when you "hot" wire it?
Old Mar 25, 2011 | 01:17 PM
pell's Avatar
Hanky thanks for your help. I have three relays there. One was the horn, one was the fuel circuit, and one the fuel unit. The one that pulled in the unit was bad(changed it out with the horn for now) and the truck starts and runs great.
Old Mar 25, 2011 | 06:15 PM
Good work. If you mark the relays while it's still fresh in your mind, if you should ever need to remember them the marking will help. As you know, if you mark them they will probably never give you any trouble again. But, don't, and after you forget, guess what?
canuck
Jan 31, 2018 12:13 AM
cat38548
Apr 10, 2007 11:07 PM
Nik_Never
Jan 15, 2007 10:39 PM
trucklovingirl
Sep 16, 2006 07:02 PM
fordmann67
Sep 6, 2006 08:27 AM
