95 7.3 DI. po267,po268po475p1263 codes
Old Nov 5, 2007 | 10:59 PM
wrenchman68's Avatar
Default 95 7.3 DI. po267,po268po475p1263 codes
fixed thank you
Old Nov 6, 2007 | 10:24 AM
david paul's Avatar
Default RE: 95 7.3 DI.Hard start, missing x4 cyl ,ck eng
sounds like injection system or computer as the injection system is computerized i would say you would have to go to the dealer or a diesel injection shop
Old Nov 6, 2007 | 10:47 AM
Could bad fuel cause this, as sometimes it will start and run ok for 1 min then lope ,chech eng lite, sounds like one side of the eng is comeing apart, tail pipe smoke looks lean then rich and so on then slowly dies.
P.S. my old man just filled it up ?
Old Nov 15, 2007 | 11:36 AM
BRETM's Avatar
Bad fuel will not cause the codes to appear. P0267 is cyl #3 circuit high. P0268 #3 circuit low. P1263 is #3 high to low side open. I would disconnect valve cover connector and inspect to see if wiring is burned, or may have to remove valve cover to inspect wiring under there.
Old Nov 17, 2007 | 02:17 PM
thank you !
r&r valve cover and there it was , burnt wireing for #3 inj. YOU THE MAN!
mauibeetle
May 10, 2009 01:19 AM
retiree
Sep 11, 2007 02:48 PM
josser
Sep 27, 2005 04:16 PM
X2halr
Jul 19, 2005 09:41 PM
rod5
Mar 28, 2005 02:23 PM
