99 F250SD Triton 5.4 gas 4wd coolant in the oil, 349000 mi
Old Mar 10, 2021 | 11:36 AM
99 F250SD Triton 5.4 Gas 4wd's Avatar
Default 99 F250SD Triton 5.4 gas 4wd coolant in the oil, 349000 mi
99 F250SD Triton 5.4 gas 4wd coolant in the oil 349,000 mi.
Replaced vc gaskets and thermostat. Radiator less than 6 mos old. Now the fluids are mixed..I stopped running it immediately. It also had a loping or surging when idling before this happened. And the old truck has squeaky suspension.
One shop told me its not worth replacing heads gaskets or do a head job because bottom end of the motor wont hold up after that. This old truck is a beauty and I should keep it.
Looking for some wisdom...
Old Mar 10, 2021 | 04:48 PM
Welcome to the site..
Did they check the engine oil cooler?
Old Mar 11, 2021 | 12:06 PM
Thanks for your suggestion. Will discuss it.
Jrp79
Oct 4, 2019 07:29 PM
Wombat
Nov 13, 2012 05:47 PM
adam10
Mar 18, 2010 06:32 PM
WindstarWorkHorse
Feb 25, 2008 11:58 AM
69wert
Jan 24, 2007 04:21 PM
