After Chngng Oil in 10spd Trans-Will Not Shift
Old Apr 22, 2025 | 07:39 PM
Ratherbefishing's Avatar
Default After Chngng Oil in 10spd Trans-Will Not Shift
Hello:
2022-F:350 / 7.3L Gas w/ 10spd Automatic Transmission:
I dropped the transmission pan and replaced the filter / Re-installed pan, added 5 Qts of Motorcraft Mercon ULV Transmission Fluid / Oil was coming out of the Level indicator / Started Truck, idled 10secs in Park / 10secs in Drive / 10secs in Reverse / Repeated Cycle / Transmission was not engaging, realized that the On-Dash Shift Indicator was in 10th gear. Whether I used the manual gear selection, or left in Drive, transmission will not shift out of 10th gear. Never able to move truck
Any ideas?
Old Apr 23, 2025 | 05:41 AM
EddyJ's Avatar
5 quarts? Doesn’t seem like enough fluid. Maybe recheck dipstick.
Old Apr 23, 2025 | 11:46 AM
That does sound like the logical issue. This is the second time changing the transmission oil. From my notes, I added 6Qts for initial startup / I added 2 Qts and the shifter is back to normal
Old Apr 23, 2025 | 02:04 PM
EddyJ's Avatar
Nice, always good to have an easy fix!
gdabel
Mar 26, 2024 06:26 AM
Sdj
Sep 24, 2023 10:34 AM
ferhad
Apr 13, 2023 10:53 AM
Yapalot
Apr 26, 2011 05:29 PM
uru
Aug 9, 2005 01:34 PM
