2022 f250 gear shift indicator
Old Mar 25, 2024 | 04:46 PM
gdabel's Avatar
Default 2022 f250 gear shift indicator
My gear shift indicator is off. When in D it shows neutral. R is P. How do I align the column shift to the desired position.
2022 F250, 14,000 miles, column shift.
Old Mar 25, 2024 | 07:47 PM
You may need to remove a small plastic portion of the dash just under the steering column, usually only 2 screws, and you will see a circular tube that goes around the steering column and to that piece of metal is usually a small size red cable that is clipped to that tube.That little cable is what moves the sliding indicator in the dash.
It is usually connected to a little spring so that when the tube is moved by the shift lever that cable also moves to indicate the shift position selected.What is usually done is to pull the clip off the tube, and if the shift lever is in the park position , just position the clip onto the tube so the indicator is in the correct location. It is much simpler than all this wind, but now you should have some idea how to correctly position that clip with the little cable attached to it.
Old Mar 26, 2024 | 06:26 AM
gdabel's Avatar
Thanks, I figured it was pretty simple.
Sdj
Sep 24, 2023 10:34 AM
ferhad
Apr 13, 2023 10:53 AM
Steveromo
Oct 24, 2012 08:25 AM
Yapalot
Apr 26, 2011 05:29 PM
stubbie
Feb 11, 2011 01:13 AM
