Block Heater Cord on Gas Truck, Temperature limited??
Old Nov 3, 2022 | 07:38 AM
Ratherbefishing's Avatar
Default Block Heater Cord on Gas Truck, Temperature limited??
Hello:
For over 5 years now, GMC / Chev vehicles factory installed block heaters have a temperature controlled block heater cords. Tell tale is a molded bulge or block just up from male end of cord. It is labelled a a temperature controlled relay that prevents power transmission through the cord when temperatures are above minus15-18C (-25-28F). Does Ford put the same temperature control on their gas motors? Driving a 2022 F350 w/ a 7.3L Gas, and would like to have the block heater functioning at -10C / -23F
Old Nov 3, 2022 | 08:25 AM
Different block heater manufacturers operate in the same general range. When correct, you have instant heat inside the vehicle on the coldest day. If not, replace the heater unit.
greg cook
Jan 8, 2009 09:48 AM
gari08
Jan 9, 2008 06:40 PM
TAB999
Aug 26, 2007 01:23 PM
Ranger Dan
Dec 6, 2006 10:21 PM
RTM
Oct 4, 2005 05:32 PM
