Brake calipers
Old May 13, 2025 | 09:26 PM
Bub45's Avatar
Default Brake calipers
In need of help I replaced 3 brake calipers on my front passenger side and they keep freezing up what is going on it's a 2011 f250 4x4 6.2 gas
Old May 14, 2025 | 07:26 AM
Suggest you consider replacing the brake hose to that particular caliper, then bleed caliper to assure all air from hose and caliper is removed.
Old May 19, 2025 | 12:37 PM
the1driver's Avatar
Consider replacing guide pins are also a culprit
Old May 19, 2025 | 07:26 PM
Good point regarding guide pins.
A little FYI,,,,,,,,,,,,,,many times they can be cleaned and lubricated. Be sure to use only synthetic grease which is not harmful to the rubber boots and can better with stand the heat generated at the caliper.
commercialpoolguy
Oct 19, 2023 06:56 PM
MartinTravels
Aug 29, 2022 03:53 PM
RockAuto
Sep 22, 2020 10:55 AM
ranchhorse
Sep 25, 2005 01:37 PM
Dr. Rich
Sep 8, 2005 01:10 PM
