Coolant explosion
Old Jul 30, 2022 | 07:45 PM
Scorched96's Avatar
Default Coolant explosion
Alright, so I have a 1993 F-250 with a 460. The other day it was 107 and I had the truck idling while I loaded some things in the bed. All of the sudden I started hearing pops and sputters like and old lawn mower and smoke started pouring out from under the hood and filling the cab from the vents, I shut off the truck and popped the hood and found that their was green coolant sprayed all over. I have since tried to find where it can from but I can’t seem to find anything. Had anybody had this happen before? I’m pretty green when it comes to mechanics so any help would be appreciated. I have attached a photo of when it happened for reference.
Old Aug 3, 2022 | 03:40 AM
raski's Avatar
I never seen coolant look so concentrated like that. Almost looks like green spray paint. A slightly wider pic showing the whole engine compartment might help.
A burst hose or a bad hose connection? You need to pressure test the system to see if it holds pressure while looking for leaks.
Quoting you "I’m pretty green". That's a good one.
Old Aug 3, 2022 | 04:05 AM
bismic's Avatar
+1. What coolant is that? ........ and who did the last flush or coolant replacement maintenance?
Old Aug 3, 2022 | 11:11 AM
Picture is somewhat puzzling, because upper hose is green , dist and some parts of wires , green and yet not the thermostat housing, questionable?
Old Aug 3, 2022 | 01:00 PM
bismic's Avatar
For sure!
Old Aug 5, 2022 | 03:44 AM
raski's Avatar
It's a special coolant which selectively targets only certain parts to collect onto.
Old Aug 5, 2022 | 07:38 AM
Have seen many coolant leaks, but nothing like this.
If possible really would like to know where that leak was, thanks.
Old Aug 6, 2022 | 03:52 AM
raski's Avatar
I do not think this thread is legit. The upper hose looks suspicious. Whatever the substance is, goes against gravity. The hose is green on the top and untouched on the bottom. Very strange indeed.
rog2867
Mar 16, 2022 06:22 PM
pd7
Mar 26, 2021 08:19 PM
lowie182
Mar 6, 2019 11:06 PM
paul64
Aug 1, 2012 09:55 PM
davidp
Jan 9, 2006 05:07 PM
