Coolant leak
Old Jun 2, 2022 | 12:30 PM
Collinhill311's Avatar
Default Coolant leak
Started out coolant leak somewhere above control arm passenger side. Engine got hot (206°f) due to lack of water. Pulled over and added water to reservoir and it immediately poured out from same location ( center/ passenger side) now everytime I put coolant into reservoir its pours out within minutes . did i crack something when i added Water to reservoir or did my water pump go out?
Old Jun 2, 2022 | 03:14 PM
raski's Avatar
We have no idea what exact vehicle/ engine you are talking about. I doubt your addition of water caused that because the engine was needing water in the first place. It should be easy to find that type of leak. These can cause a bad leak as you describe. Ruptured hose, loose hose clamp, leaky water pump, cracked block or a freeze plug problem. You could pressure test the cooling system, if it will hold long enough for you to slide under to see.
Old Jun 3, 2022 | 01:06 AM
Oh oops. I meant to add Its a 2008 f250 6.4 l power stroke. It doesn't seem to leak very much when the truck is on but the minute I turn it off it dumps every bit of water
Old Jun 3, 2022 | 03:23 AM
raski's Avatar
Then it should be very easy for you to see where the leak is.
Old Jun 3, 2022 | 10:04 PM
The leak seems to be coming from behind the fan clutch I think. It doesn't leak very much when the truck is running. But it still over heats. I've removed the inner cooler radiator. And am Going to remove the fan shroud in the morning . I was told that I could reverse thread the clutch to remove the fan and access the water pump seal behind it. Does what I described in my earlier posts sound like it could be the water pump seal? And if so is the process I'm taking (as far as removal of components ) correct to access the water pump seal?
Old Jun 4, 2022 | 03:31 AM
raski's Avatar
Yes, a good possibility it could be the water pump. They can leak out the weep hole on the pump's bottom or the front shaft seal itself. If the pump is bad, I would also change out the fan clutch. I always the clutch when replacing a water pump.. Many times, the clutch can have a slight wobble and can ruin a water pump in no time and be the real cause of your pumps failure..
Old Jun 4, 2022 | 03:38 AM
Oh really. ?ok thanks for that advice. Ill probably change that too
Old Jun 4, 2022 | 05:37 AM
While you are in there, consider replacing the thermostat and serpentine belt. If your vehicle is approaching around 100,000 miles , good time to replace the tensioner assy.
Any one of these parts will require a considerable amount of time to replace alone, it might cost some $$$ to do this now, but nothing compared to if one of them lets go on the road.
Orby24
Jun 4, 2022 05:42 AM
Denver Burns
Dec 27, 2018 02:15 AM
ps0303
Mar 12, 2018 10:27 AM
F150-Utah
Oct 23, 2011 10:10 PM
jr1017
Jul 25, 2007 09:54 AM
