Diesel Injection Pump
Old Sep 3, 2008 | 04:45 PM
musicfire1's Avatar
Default Diesel Injection Pump
Greetings and thanks for the replies. I have a 1991 f-350. 7.3 diesel. I recently repaired a leaking fuel line by splicing in a section of hose. Since then I've had some difficulty starting the truck. I thought it might bebecause of air in the system.It does start but with difficulty. I took it to a repair shop and they tell me they want to change the "Diesel injection pump ". A $600.00 part plus 10 hours labor. The truck had no prior history of starting difficulty before I replaced the line. Could this have caused that pump to go bad or could they be mistaken? If that pump is bad wouldn't the truck not start at all? What are some other symptoms of a badDiesel injection pump? Thanks!
Old Sep 4, 2008 | 11:03 AM
Default RE: Diesel Injection Pump
A failing injection pump can make for a harder than normalstartup that can be temp sensitive, or after a longer sit time.. You may also see excessive emissions or 'puffing' from the tailpipe on a hard acell. or a high raised RPM stationary. A clear tube installed in the line can/may reveal air, but if the pump is weak, or original, it maybe time to change it out.. A reman. fuel injection pump should be about half of the price you posted,a little higher if they add to the purchase cost, but the labor time quoted is way off..
twj815
Oct 13, 2013 09:17 AM
67plymouth
Dec 28, 2011 05:12 PM
JP
Jun 30, 2006 01:11 AM
fordbronco351
Apr 8, 2006 06:38 PM
sideways4m
Sep 9, 2005 07:05 PM
