Dtc p054f - 2016 f350 6.7
Old Feb 21, 2022 | 02:50 PM
KampLyf's Avatar
Default Dtc p054f - 2016 f350 6.7
Any suggestions to resolve P054F default code? Idle Control System - Fuel Quantity Higher Than Expected
Internet search is all over the place from replace fuel filter to torque converter issues.
In addition to CEL with above code.
When I hook up my 5th Wheel Camper ~13k# the truck will not move once in gear. Only idles when applying accelerator.
Have an appointment scheduled with dealer but was looking for any possible feedback here.
Thanks.
Old Sep 2, 2022 | 05:49 PM
Fat guy little coat's Avatar
Thanks.
I have exactly the same issue and have spent a lot of money trying to figure it out plz let me know what it was thank you
Richard 9047255242
Old Sep 4, 2022 | 11:43 AM
I would be inclined to confine my efforts to the converter . A defective one way clutch could very likely be failing . They never get better just worse..
There are some problems if the converter ever was replaced and a converter for a small gas engine was installed where the proper one for a diesel should have been installed. They will both fit , but one is built to handle more power than the other.
Old Sep 4, 2022 | 09:46 PM
thanks for replying so this all started when the low pressure fuel pump started making noise and the gas pedal would do nothing when floored and hooked to heavy load so we have replaced fuel pressure regulator and now have installed a fass fuel pump. So with koeo fuel pump comes on and after about 15 seconds pump starts getting loud and fuel stops returning to tank so I'm thinking fuel pressure regulator on cp4 pump but I just read that it is spring loaded and opens at 53 psi and is not controlled by fuel pressure sensor can anyone confirm this?
Old Sep 5, 2022 | 06:27 AM
You are dealing with a diesel engine and the answer you are seeking is for a gasoline engine.
Old Sep 6, 2022 | 03:54 PM
can you enlightening me more with your theory.
Old Sep 6, 2022 | 04:42 PM
To the best of my knowledge,a Ford 6.7 is a diesel engine.
So , is the engine you are concerned with a gasoline powered or diesel powered engine?
Appreciate your tact in requesting some enlightenment.
If it is not a diesel powered engine ,what is the correct displacement?
Old Sep 12, 2022 | 06:34 PM
Put new valve body in transmission and fixed problem.
hope this helps someone someday.
Old Sep 13, 2022 | 06:54 AM
Thanks for the update.
DD77802
Aug 8, 2021 10:08 AM
2ndwindranch
Apr 29, 2021 06:03 AM
wait4it
Oct 15, 2016 03:23 PM
Mark2Tracy
Mar 1, 2016 10:05 AM
Larry Joe Gunkel
Sep 19, 2015 02:20 PM
