F350 door chime disable
Old Nov 29, 2019 | 06:34 PM
DD77802's Avatar
Default F350 door chime disable
Any know how to disable the door chime (key in) using forscan I have found plenty of links on f150s but nothing on f350s
Old Nov 29, 2019 | 09:13 PM
Welcome to the site.,
What year 350?
Did you look in the FORScan config/programming forum? I thought there was a few posts about IPC block code rewrite for canceling the chime function..
Old Nov 30, 2019 | 06:16 PM
DD77802's Avatar
Default door chime f350
its a 2016 f350 xl when I bring up the programming with ford scan it has a 720-01-02 9d69 8b16 00d1 nothing like a f150 and I cant find much info for a 2016 f350 any info I can get would b helpful I leave the door open a lot to listen to music or talk and the chime is annoying
Old Dec 1, 2019 | 06:16 PM
DD77802's Avatar
anybody find anything on disableing door chime on a 2016 f350xl with ford scan
Old Dec 2, 2019 | 08:18 AM
What if you just left the windows down?
As you are aware, when the doors are in the open position , courtesy lights also are on and drawing power from the battery..If done long enough , it could cause a starting problem.
Old Dec 2, 2019 | 08:03 PM
DD77802's Avatar
na way to much time and effort to put the windows down every couple mins up and down none stop then ill be putting window motors in it I know I can stop the chime by removing the door panel and short capping the door latch plug or flicking the striker on the latch but I would like to disable it easily with forscan like you can in the f150s
Old Dec 3, 2019 | 09:24 AM
bismic's Avatar
That was the first mod I did on my 6.0L. When getting in and out of the deer blind, I didn't want any chance of the chime going off!
Old Dec 3, 2019 | 10:50 AM
720-01-02 is 9d69 8b16 00d1 whats in the block codes for 720-02-01?
Old Aug 6, 2021 | 01:40 PM
GE200F's Avatar
Default Door chime solved
Well for all of those that think you can't disable the door chime on a 2019-2021 F-250 & F-350, you are wrong. Out of personal necessity I took my 2019 F-250 to the local repair shop that is well trusted where I live and when they looked at it they said there is no way to turn it off, just like everyone else thinks. I had previously called reputable dealers as well and asked them about it and received the same response as everyone else. What I did find out from my local repair shop is he the schematic for the key in the ignition. It's pretty simple. A power wire comes from the fuse panel (fuse #18) on the passenger kick panel to the key switch and when the key is inserted another wire sends the signal to a computer. So I traced the wire to the key switch and unplugged it. It's the blue/grey wire that goes into a connector on the LH side of the steering column. The plastic is easy to take off of the steering column and you Do Not need to cut the wire. Unplug the connector, pop the red thing out of the connector and use a little pick or screw driver to release the terminal. Its the 3rd wire up from the bottom of the connector. Everything else will still function as it's supposed to with this wire removed. The only thing that is disabled is the stupid door chime when the key is inserted. And it didn't take a genius to figure this out.
Your Welcome!
3rd wire up, but it is the 4th terminal
Old Aug 8, 2021 | 10:08 AM
GE200F's Avatar
I posted how to do it on here but for some reason it's not here. You don't need to use forescan. It's as simple as removing a wire from the plug on the LH side of the steering column for the key switch. It's the 3rd wire up from the bottom blu/gry on the 2019 and newer F-250/350. Not sure on the older models because I haven't seen them.
Squeezed
Jul 27, 2021 12:48 PM
Short Arm
Dec 11, 2018 01:28 AM
kyle 90
Apr 16, 2011 09:40 AM
luker
Apr 26, 2009 08:34 PM
newguy18
Oct 26, 2007 07:07 PM
