excursion codes
Old Sep 17, 2013 | 05:11 PM
rubberband's Avatar
Default excursion codes
I have a 2000 ford excursion with v-10 engine the service engine light has recently come on andbeing checked at az says 02 sensor right bank so i changed it the light stayed off momemtarily thus going back to az code reads 02 sensor for laughs and giggles i changed in hope of bad sensor light still comes on.Any suggestions going broke between gas and sensors
Old Sep 17, 2013 | 05:15 PM
It would be more help if you had the exact code number since there are 4 O2 sensors on your vehicle.
Old Sep 17, 2013 | 05:22 PM
rubberband's Avatar
Default codes
Ok hanky dont recall just yet will retrieve an dget back thanks for reply
Old Sep 18, 2013 | 09:17 AM
rubberband's Avatar
I had my 2000 excursion v-10 checked and it comes up with codes po135andpo155 any other causes besides 02 sensors have changed both
Old Sep 18, 2013 | 01:57 PM
The description I have for those codes involves the heater circuit for both of those sensors. The first thing I would suggest that you check would be the fuses. They are turned on by the PCM (powertrain control module) but protected by a fuse. If one of those sensors you removed was defective it could have caused a fuse to blow. So could a wire feeding the power to them that might have been touching something and worn off the insulation. I don't know at this time which fuse it could be , but if you have the owner's manual it would provide a description of what each fuse protects. You would just read and look for the fuse that says oxygen heater circuit.
Old Sep 19, 2013 | 07:06 AM
rubberband's Avatar
Thank you hanky for your response will try .
akturndbelle
Oct 14, 2005 01:01 AM
wwjd216
Jul 20, 2005 07:08 PM
hauserc
Jul 18, 2005 09:22 PM
llogan_jones
Jun 10, 2005 03:49 AM
wwjd216
Jun 7, 2005 06:43 PM
