F250 4wd problem
Old Apr 13, 2005 | 09:25 PM
hdvixen's Avatar
Default F250 4wd problem
I'm having a problem with my 96 F250 going into 4wd while driving. Specifically, it usually does it if I make a right turn. You can feel the tires are different and hear the sound the tires make when it's in 4wd. The light on the dash doesn't come on but you can feel the difference. When I stop and put it in 4wd and then drive and then take it out of 4wd it stops. Only to do it again when I make a sharp right hand turn.
I have had a few people tell me that I need to change the hubs to manual. What parts do I need and how much should they cost? Why is it doing that too? Seems like they would have had a recall on that because if you let it go it can be very costly to fix and replace right??????
Old Apr 28, 2005 | 01:36 PM
skip's Avatar
Default RE: F250 4wd problem
sound like you might have a limitted slip diferental in the front???
Old Apr 29, 2005 | 07:37 PM
truckpuller's Avatar
Sounds like you have an actuator problem that locks the front axles in and its not dissengaging all the way. Could be electric or vacum operated.
hilliad
Jul 4, 2010 02:26 PM
rut
Jun 11, 2010 04:18 PM
William Homan
Mar 23, 2009 11:50 AM
W30467659
Jan 1, 2008 08:39 AM
BENBROUGHTON1320
Dec 12, 2007 11:05 PM
