F250 Diesel Stall
Old Sep 20, 2007 | 01:59 PM
jajharley's Avatar
Default F250 Diesel Stall
I have no problems pulling any load or really giving it the gas. My problem starts when I leave a red light or stop sign and around 1500 to 1800 rpms the truck acks like I've cut it off. IT WILL DROP RPMS SO FAST AND COME RIGHT BACK UP. If it does this a couple of times, the engine light will come on. I've already replaced the timing sensor on the front right above the crank pulley. Need some help. John
Old Sep 20, 2007 | 05:26 PM
Default RE: F250 Diesel Stall
It would be a big help to have the DTC read (Autozone ect.) and post the code..
Old Jan 18, 2008 | 12:51 PM
stroker's Avatar
its a cam positioning senser. i had the same problem about a month ago
Old Jan 26, 2008 | 08:25 PM
OR97601's Avatar
I had that problem about a year ago. for me, it only happened when there was a lot of humidity (heavy fog, rain, etc...)
I think the shop said it was the mass air sensor.
Old Feb 3, 2008 | 02:09 AM
Level2's Avatar
ORIGINAL: stroker
He already said he replace the CPS. Do you have an aftermarked chip installed? I had problems with corrosion on the pcm terminals when I had a chip installed on my 95 and it would cause stalling and stuttering.
Old Feb 14, 2008 | 02:11 AM
6Leaker's Avatar
If you've got a 7.3L there's a recall on the CMP sensor. F7TZ 12K073 B is the part number.
Old Feb 18, 2008 | 12:33 PM
SUPERDUTYCHIC's Avatar
I have had multiple issues with my 6.4 so far Ihad a new thermostste put in , a pse sensor and now she's in the shop again 85 miles later. 6773 miles on my beautiful Big Rig. I also have poor fuel milage 10 mpg.I don't pull much a four wheeler and boat and I sure don't baby her much. see if you can get a diagnostic done P0196 seems to be my trucks favorite so far.I should have went with the V-10 never had a lick of problems with that "99" 180,000 miles and she still ran strong. I guess never isn't always better.
Good luck
Old Feb 23, 2008 | 08:38 PM
hobbywelder's Avatar
having the troble code would help but sounds like tps (throtle position senser)sorry about the spelling
90f250
Dec 29, 2014 06:07 PM
1FAT250
Apr 20, 2008 06:00 PM
TBIRD_TURD
Aug 20, 2007 09:11 PM
LJakey
Apr 29, 2005 04:36 PM
